laguna intercoler, hose problems
exsaxoboy!
125
sutton BRUM
Right, fitted the cooler today, all well apart from the 135degree hose doesnt seem to line up too well to the black standard hose, which means theres a kink in the standard one. Any one else had this problem. Any help much appreciated.
flashbsd
i had a slight kind, but i ended up buying a 135degree 63mm hose, and joinign it to the 63-51mm 45 degree reducer. this made the bend much better. although didnt make any difference to the performance or airflow.
EDIT: are you talking about the one in the wheel arch or the 135 that goes up and connects to the 10cm black hose near the gearbox?
exsaxoboy!
125
sutton BRUM
im talking about the one that joind onto the ovalised plastic tube. im sure this willl restrict airflowas its kinked to the point wher the standard pipe has gone oval in the bend.
karl.w
methanol junkie
Oct 26, 2005
606
what i done with mine was to fit a extra bend it's about 110 degree.
as it was kinked far to much for my liking
not great pics but you get the idea
karl.w
methanol junkie
Oct 26, 2005
606
i got it and the rest of my pipes out of work:cartman:
but you should be able to get one anywhere
