KW or Weitec Susp Kit for an LCR
DamianPM
6,389
84
Newcastle/Durham
Fitting will usually cost between £100 and £200 depending on where you go but it is just basically a straight suspension swap except they'll need to set the height up as well.
Damian @ DPM Performance
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
i think il go weitec shocks and some 40mm springs fit the rears myself and get the specialist's to do the front.
30mm not enough and the 50mm to much.
Mar 26, 2007
2,020
S.Wales
The KW kit is very good, I've had it on for a few months now. The main differences I have noticed are slightly more rebound than standard so you notice a slight bouncing down the road feel on bumps and MUCH better road holding, the car feels much more planted on high speed sweeping bends and gives alot more confidence that its not going arse out any second.
The height is good as I don't really hit speed bumps anymore than I used to. Had four people and luggage in the car on the way to the V festival last weekend and the rear wheels were well into the arches, don't think I'd want to go any lower.
DamianPM
6,389
84
Newcastle/Durham
Glad to hear it.
Eibach only sell the bars in a kit or just the front, we only have Whiteline who sell the rear alone.
2footpegs
117
hi, when lowering 20mm to 30mm on a lcr do u need a different ARB or can you stick with standard and if so would i need to change the droplinks? thanks
