Koni Shocks + E SportLines?
Jun 1, 2009
423
west lothian
:( bad news today for me driving home today 70-80 on the motorway and my esp light came on and stayed on not sure if its due the springs lowering or dampers or is just randomly that happened dealers closed too so i have to call in the morning lucky its covered for a year's warranty don't think the springs would of caused it tho? Im guessing its a faulty abs sensor (common issue?) car drives fine but i don't have traction control no more this has happened for only 2 hours but light has stayed on i have jet blasted the wheels clean...even d/c batter heh but nought nothing so I guess i have to wait and see what SEAT have to say. I am right that LOWERING springs would not cause this?
Maybe wiring disturbed or damaged whilst changing springs?
May 25, 2008
1,919
S.Wales
www.seatcupra.net
still odd i don't have a vag com to check its going be tomorrow where i go to a local vag specialist to get a read i think they charged me a tenner last time but im going to try and book a slot at the dealers for friday...hopefully im still confused whats happened tho i really hope its not the springs that caused it but didn't have a good experience at the garage i went to have it done.
yes, but if you put the wheels on full lock you might be able to see the connections the run from the top of the inner wing to the strut and should be clipped in two places. Out of interest have you checked the fuses ?
May 25, 2008
1,919
S.Wales
www.seatcupra.net
not checked the fuses your refering to the fusebox? thank you* if i see the connectors should i disconnect and reconnect aswell or just make sure they are tightly clipped on? just so you know i have no abs or esp at the moment heh they no longer function right now. (edit)
