knocking noise
malky39
198
Southside
in the past few days i have hears a knocking noise coming from my engine, now its an fr tdi so its noisy at the best of times but this is a different noise and alot more vibration its only noticeable on tick over and goes away a bit when i put the clutch peddle down or completly when i take the revs to over 1000rpm, anyone any ideas
malky39
198
Southside
cheer for the quick reply. yeh its rhythmic, am not so mechanical minded but its that an major problem if so looks like it will be a another trip to the stealers for more warranty work
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
If it's rhythmic and goes away when you press the clutch down, I'd 99% say it's the flywheel. I'm no mechanic but pretty sure that's what it is. If it sounds like a train on tracks, like tickedy tick, tickedy tick then mine does it too and it's the flywheel on mine that's on it's way out.
Mar 8, 2007
831
I've got the same on my Fabia VRS.
Start the car up and no noises at idle or when clutch depressed.
However if I take it for a drive and give it a little bit of stick, then come to a standstill, take it out of gear and let it idle, I can hear like a "click-a click click" every 3-4 seconds rythmically. That's only with the fans off and the music off though.
I havn't had any clutch slip at all though. Car is on 46k and has about 5k on a P Torque map.
malky39
198
Southside
That near enough the same for mine and its only done 11000miles with no map and only 3000miles on the current engine
Wingnut_Kiteboy
Its the Dual Mass Flywheel
Symptoms : Knocking noise, press clutch it goes away. car 1.9TDi MK4
its something called the dual mass fly wheel, If you want to know what one is then there is a good video on you tube.
Si
FR TDI
Hi. That sounds similar to the noise my car (2007 TDI FR) was making a few months ago. It made an irregular clunking/ticking/rattling noise that gradually became more noticeable over a week or so. I could hear it at tickover. Sometimes depressing the clutch stopped it, other times depressing the clutch actually started it.
It then got to the point when I could hear it while the car was moving. By this point I'd decided to get the car checked out. From what I remember, the mechanic said that the flywheel had thrown all it's grease/lubricant (I think). Pretty worrying given that the car was under 20k and less than 2 yrs at the time. I didn't realise it was a common problem. Bit worrying.
Fixed now but just hoping it doesn't return!
malky39
198
Southside
cheers for all the answers, its going into the stealers tomorrow morning do hopefully will get it sorted knowing my luck it will have disappeared when they take it for a test drive
Wingnut_Kiteboy
make sure you tell them to take a look at the flywheel
I hope they are not dismantleing the gearbox !!! the Dual Mass Fly wheel is between the Gearbox and engine, if the people fixing the car are not Seat / VW People make sure you tell them to take a look at the flywheel, I had EXACTLY this problem with my car. and its quite common, bit expensive as new dual mass flywheels are 350 quid and they have to split the gearbox - engine although spliting the two is not the hardest job i've done. its a lot better than having a gearbox problem
malky39
198
Southside
yeh dont think they are dismantleing it maybe just taking it out, it is a seat/vw dealer so i hope they know what there doing. as for cost i certainly hope it wont cost me a peeny as the car is still under warrenty
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
nice to hear :thumbup: (sometimes they can be real b£&%!£$s and say that they're wearable parts so are not covered)
