djfixter
Ok guys...
Have a problem with my Arosa 1.4 Sreg.
On the motorway every so often it will suddenly pull to the left and then stop doing that.
Also for a while when the car is in motion there is a knocking noise... as the while turns about once every revolution. Definately front drive shaft.
Also when on full lock there is a grinding noise.
I have had the wheels aligned, still the same.
I suspect that it is a CV joint? I dont know much about cars... how many cv joints are there? are they easy to replace... I can see Arosa ones on ebay are about £18.
Should I take it to a garage or try and DIY?
Dale.
Dale.
