Hey all been looking through all the threads about programming your new flip key to the car.
I bought a 433Mhz VW key off of Ebay code HLO 1JO 959
My original remote 2button key was 433MHZ 5FA 007 680 think these are the numbers that refer to the part code etc!!
Now i cant get the new key to program to the car which is p*ssing me off to say the least!!
These are the one's i've tried!!!
1. Key in ignition and turn on so dash lights turn on
leave it in there for a couple of sec's then remove it
hold the lock button down and whilst holding that press unlock 3 times
release both buttons and the remote light should flash 5 times but it should also lock and unlock doors, programming the remote to the car
2. igintion on
lock the door using a second key
using remote control press the unlock button once and the horn will sound once
wait 6 secs and press unlock button once to activate the coding procedure
switch off
remove key and check for operation
3. put original key in ignition
then lock door with new key and remove key
then press unlock and horn will sound wait 6 secs and press unlock again
4. ignition on
turn off imediately and pull out key
hold 1 of the buttons down (doesnt matter which one)
press the other 3 times with a slight pause 1. 2. 3
watch led on key (should flash) and doors usually lock and unlock
turn ignition key back on to red lights and wait 5 secs
key out again and test
There is a few more but im bored of typing..
they were by funkyfin2000,
Please please help or im going to shove this remote back up the ebay's arse!!
2. igintion on
switch off
4. ignition on
