cupralooks
More Power Needed
Jul 3, 2006
579
Hi all,
Are you able to get the internals of the Ko03s turbos changed so that it is able to run more boost? or would you just get a different turbo? is which ones??
Kind regards,
Alex
sure k03s runs k04 internals does it not? just in the k03 housing..
could be wrong..
K03s can have other internals put in it which then makes it a hybrid which takes modification. The k03s does not have k04 internals. A k04 can be fitted but its no where near as easy as the k03s as you need to modify the downpipe and oil return line and need a different manifold, injectors, maf and tip to get the best out of it.
