K03s help...
starletcraig
just got hold of a K03s as an upgrade for my mk3 ibiza cupra..
aside from cooler do i need any other mods to run this turbo once its mapped???
cheers craig:)
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Exhaust manifold (ATP or similar)
3" DP & 100 Cell Cat & cat back system
Bigger TIP
FMIC
I'd put all of the above on before it's mapped for best results and you'll need a 4 Bar FPR as well.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Depends who maps it to weather or not you would need the 4bar fpr.
2.75" DP is also sutible for a k03s.
deanrankin85
219
Stoke-On-Trent
you dont NEED another manifold as the k03s will fit on the k03 manifold! so will the standard turbo pipe or forge TIP.
but to get the most you could do with all of the above!
Mar 10, 2005
1,439
Walton on Thames
the metal part of the oe tip joining the tubo won't fit iirc as the k03s is a couple of mm larger . you're best off getting the forge tip, I highly recommend it.
