Do any of these make any noticable difference in performance or economy?
Or is it mainly to avoid replacing all the time?
Seems a bit cheap to make any real performance difference.
Would it be classed as a modification by the insurance company, or just as using a different manufacturer for a spare part?
Do any of these make any noticable difference in performance or economy? - varies from none to helps the turbo spool up a bit quicker.
Or is it mainly to avoid replacing all the time? yes this is a big advantage
Would it be classed as a modification by the insurance company, or just as using a different manufacturer for a spare part? a replacement panel filter should not be classed as a mod.
My insurance company for previous cars did think it was a modification.
Performance gains are minimal to a standard car - althought air does flow more efficiently without the drop in flow a normal paper element has it gets dirtier and dirtier.
Main advantage for me is the cost - cheaper to run over 3 years than conventional filters
