markster
My 1.4 8V Ibiza ran on 10W-30 Castrol Magnatec for the last 2 years.
I just changed the oil yesterday afternoon and had about half a bottle of 5W-30 Castrol Magnatec and half a bottle of 15W-40 Castrol Magnatec so I mixed them.
I came to start it this (cold) morning and it struggled a little, although was fine once warmed up.
Could it be a problem with mixing the oil viscosities (even though I used same brand) or is it likely that it's because it was cold this morning and I didn't turn over the engine much after replacing the oil and filters since yesterday so it just took time to get into the engine parts?
Just a little concerned
You should probably be ok mate, if there both synthetic (which they are). They will both dissolve in each other i would imagine giving you an oil with intermediate properties of both.
As for mixing Synthetic with Mineral i wouldn't recomend it, but if worst came to worst you should be ok in a reasonably modern car with good seals.
Keep an eye on it and if in anything else develops, post up.
ok so reading this i think ill be ok but just to maked sure....... i was usuin 5w30 part synthetic on my leon cupra 180. did an oil change yesterday and decided to start using 5w40 fully synthetic as i was told its better. but i still have 2l of the 5w30 part synthetic left. will this still be ok to mix in?
