just bought a ibiza fr tdi :D
nvidia
2004 Seat Ibiza FR TDi
May 16, 2009
147
Reading
just bought a ibiza fr tdi, just bought one, it is so nice to drive :p... but this is the first time that i have a diesel car, what sort of maintainance are required that is different from a petrol car? what things i need to look out for?
cheers :lol:
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
not a lot to say.
usual checks for water, oil etc.
Try to wait 20~30 seconds before driving off and after stopping to let oil pressure on turbo stabilise. (lengthens life of turbo)
Other than that service at correct intervals and happy motoring !
Ian:whistle:
p.s what year is it, colour etc etc?
nvidia
May 16, 2009
147
Reading
mine is 2004 54 plate, and in red, it has done 75000miles on the clock, with service history so its pretty gd.
However i have discovered something today, i had been given 3 car keys, 2 of them will start the car also open anything apart from the door locks, (unless using the remote) the 3rd key it will only open the door, but will not open anything else e.g. fuel tank caps or start the engine, so JUST the door lock. Anyone else has came across this before??
EDIT: It is a seat car key, it look different, so i think the previous owners has changed the lock ><
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
Yes, sounds like that lock was changed. Probably some thiefing chav punched the lock in to try and break in!
nvidia
May 16, 2009
147
Reading
would it be possible to change the lock back to the same as the car key that would start the engine? in case of anything like remote stopped working, i will still be able to drive the car. rather than carrying 2 car keys at the same time
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
I honestly don't know! You would have to go through the stealers for this so you might as well ask them. It would probably cost a fair bit too!
nvidia
May 16, 2009
147
Reading
mmm....might be just get em to make me another key that would open the door, seems thats the cheapest way, so i will be able to get in the car even remote is not working!!
SteveC123
Torquing TDI
Jul 5, 2009
81
Have a word with a decent locksmith.
The one near here once stripped a lock down and re-pinned it so it worked off the same key as all the others the car in question had, so it might be possible they could do this for your car as well. :)
SteveC123
Torquing TDI
Jul 5, 2009
81
Like I said, speak to a decent locksmith.
If they're anything like the one near here they'll do the above, be that with you removing the lock from the door or them doing it for you.
The main thing you need to initially find out is whether they can re-pin a SEAT lock or not.
nvidia
May 16, 2009
147
Reading
enjoy the FR. how long before mods start?? what some idea click 'my ibiza' in my siggy
i might save a bit of money first since just spend money on this car, then get the cupra or facelifted fr bumper wiv splitter, painted and fitted :p ....then idk yet =p.... probably get some bright headlight and polo rear wiper soon
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
HIDs........... £36 from diana shop on ebay;) polo wiper £20 from dealers:)
Lippo
YNWA
May 8, 2006
395
Formby
http://www.seatcupra.net/forums/showthread.php?t=229511
I've sort of explained what to do and included the part numbers required on the thread as well. It's very easy to do - remove the old cap, undo the nut, remove the old wiper arm (might be a bit stiff). Put new wiper on, tighten nut back on and place new cap on. The cap might rub slightly against the rear windscreen, in which case a bit of sandpaper rubbing on the bottom of the cap will sort it.
nvidia
May 16, 2009
147
Reading
ahh cheers
i might sort it out later since i had to sort out my rear break disc are worn >< money go to safety first
*Lou*
Princess Lou Lou
Jul 28, 2009
146
Edinburgh
www.bebo.com
Maintenance on a diesel is just the same as a petrol, still looking out for the same sort of things- water/oil leaks etc. You just need to service a diesel more regularly to keep it running smoothly, and to cut down on smokyness! :D I only know because I have a 1.9 Sportrider lol
