DVT
Hi ... just joined, first post and after some help! Sorry about this long story but I'm getting a bit desperate!
I have a 56-reg Leon 140 TDi 2-litre 6-speed, bought from a Ford dealer in April 2011, it has clocked up 71k (22k in with me). Recently I have experienced juddering when accelarating gently from about 1500 to 2000rpm - noticably in 5th or 6th gear under load (going up steady inclines). By feathering the throttle to get through that range it is fairly smooth and once over about 2300rpm not noticeable.
It was due for a service so took it to the independent who did the last service at about 60k. I told him the symptons and he told me straight-away it was dual-mass flywheel, so go the SEAT dealer as there had been a recall, although didn't know when. He also warned me about the cost. Others that I know inn the trade also said dual-mass flywheel, also common on Fords.
So, I take it to SEAT dealer who insisted on checking it out - they didn't try driving it but took it in the workshop and agreed it was dual-mass flywheel, but the recall did not affect my car as it was a later build. So car gets booked in. In the meantime I contacted SEAT and after some discussion get an agreed discount.
Flywheel and clutch (Sachs) get replaced. I cough up and get the car. I noticed it had clocked up 9 miles so had obviously been out on a test run. On the way home I get the juddering again. Phone dealer (it is about 25 miles from home) and was asked to take it back the following morning.
Take it back, mechanic shows me the flywheel removed and it was kna****ed - shook around so definitely needed changing. He now reckons it could be the EGR although had only ever come across that on an Ibiza 1.9 TDi (which is what I had before the Leon but didn't get that symptom!). Mechanic comes out with me for a run and he sees/feels the fault - from 1500rpm upwards when accelarating there is a horrible juddering - not the EGR he says, could be the fuel filter - when was it changed? Last service says I. What about the cambelt - don't know says I, was planning on that when it reaches 80k.
So, car gets booked in again and they've now had it a week (they have kindly lent me a Mii) - they replaced the fuel filter (said the one in was not a genuine VAG part) but symptom still there. They've used a stethoscope to try and trace the noise as someone presses the go pedal. Now suspect injectors (another big cost).
I've said I will pay to have it sorted, but not pay for any parts they fit that doesn't cure the problem. They have said cam belt should have been changed when car was 4 years old (I've seen 80pk as being the change time).
Anyone have any ideas as to what it could be? - I would have expected a main dealer to sort it out. Testing on their computer shows timing to be OK.
I have had work done by the dealer before - my previous Ibiza was bought from them, the Leon did have an air flow motor (?) changed a while ago.
All help gratefully received - thank you.
Dave
Dave
