Ok, thought it was coil packs, but have disconnected them one at a time (and tried disconnecting the injectors one at a time) and doesn't make any difference disconnecting any of them... which i find very odd?!
engine judders horrendously when cold and idles incredibly lumpy at around 700rpm...
once warmed up it runs ok but you can feel it's missing every so often. and when cold it jumps on even light acceleration, kinda kangaroo style!
any ideas? if you need any more info i'm more than happy to answer questions, or try anything you can suggest?!
thinking might flush the fuel system with Forte, and maybe disconnect the battery for a while to re-align the throttle body... anything is worth a go?!
could it be lambda probe? coolant temp sensor? MAF?
cheers guys
oh, for info, have just replaced all plugs, and also the two H type coil packs... now got two new "R"s, an L and an M... and didn't make any difference...
cheers guys
