hey guys,
ive had the car nearly a month now and ive been getting really bad MPG no matter how I drive, around 350 miles to a full tank (50 quid) at most, which is like 30 mpg.
a couple of weeks ago I noticed a turbo overboost problem. got diagnostics on it and fault was:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
anyway, I basically:
- replaced N75 valve
- replaced valve that goes underneath EGR (not N19)
- fitted new timing belt (as it was squealing).
- timing was off, car took ages to start. sorted now.
- replaced waterpump
- got car fully serviced (air/fuel/oil filters + oil change + glow plugs)
- checked MAF by unplugging it, car ran much worse so I assume MAF is ok
- replaced engine temp sensor (G2?)
- replaced vacuum hoses
all using genuine oem parts
after all that, the car kept going into limp mode but not as often. I put in some forte diesel treatment and all of a sudden the limp mode is gone. i confirmed this by going uphill at high load which ALWAYS put it into limp mode but this time it was fine.
anyway, Im still getting really bad mpg (30mpg) even when I drive nice and easy. It also takes a while to start the car in the morning. any common reasons why?
any help is appreciated.
thanks
update: when my mechanic did the timing belt change, he said there was a lot of carbon buildup. he recommended I clean the intake manifold/egr valve. would this contribute to the problem?
thanks
