Hudson
389
Bilston.
Probably not a common fault but I've noticed today that when i turn a sharp left corner my passanger speaker stops working.
First stupid question is has anyone else had this.
Second question how hard is it to take the door card off (or get access to the speaker).
Its under warrenty is this sort of thing covered - should I just get the dealer to check it out.
H
If it was under warretny I'd ge tthem to sort it out no point touching things them taking it in and them not covering it. If you want to though taking the door card off is easy there is guide in the FAQ section saves me explaining it! Sounds like the speaker maybe shorting out on the metal of the door as you turn I had this in a differnt car.
Get it looked at and please post with that they say.
I had this occasionally when it was under warranty but ignored/forgot about it.
Now the car is coming up to 5 years old and only 3 of the 8 speakers work all the time and one or two start working when I go around a hard bend or a big bump :) The opposite of your problem.
