Kimmsy
hi guys i'm havin toruble with my ibiza 1.2 55 plate. its had this interminant fault since i've ad it and nobody seem to know wha it is. main dealer said it was power steering pump so tha was replaced but its now comming up with the same error which is abs and handbrake light come on briefly then go off untill something triggers it again.
it seems to b a power problem as when it was having a moment i flashed some1 on the road n everything went off for split second radio,lights on dash but engine was still running. garaged plugged it into computer n it said intermitant fault terminal 30. which is main feed any ideas how i can issolate where the fault is as i dont no if its the alternator or wiring..
many thanks
Kim
many thanks
Kim
