interior light fuse location
steve carter
191
Poole, Dorset
Just changed my interior door lights to led and i have blown the fuse, does anyone know where this fuse is and which one it is and what amp it is. Yes i have tried the search function but it seems all i can find is evey other seat model but what i need.
jon_boi_91
120
im guessing, but what about under the steering wheel? pop the little pannel off and on the panel, you will have fuse numbers and what they operate :) pull it out and see if its blown.. replace if necessary and voila :)
steve carter
191
Poole, Dorset
found the fuse box at the end of dash, no written explanation just little pictures, need to know which fuse box it`s in and fuse number, or even diagram or link to one so i can do it myself. Tried a search on google, what a waste of time that was.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Layout of fuses
No. Component A1)
1– Heated washer jets,
heated mirrors......................... 10
2– Indicators ............................... 10
3– Lights ..................................... 5
4– Number plate lighting ............. 5
5– Comfort on and off .................. 7.5
6– Central locking ........................ 5
7– Reverse lights ......................... 10
8– Telephone............................... 5
9– ABS ........................................ 5
10– Petrol engine control unit ........ 10
11– Instrument panel..................... 5
12– Supply current, diagnosis,
telephone ............................... 7.5
13– Brake lights ............................ 10
14– Interior lighting, central locking/
electric windows...................... 10
Interior light ............................ 5
15– Instrument panel,
automatic gear box.................. 5
16– Magnetic clutch, electric
water pump............................. 10
17– Free ........................................ 7.5
18– Main beam, right ..................... 10
19– Main beam, left ....................... 10
20– Dipped beam, right ................. 10
21– Dipped beam, left.................... 10
22– Side light, right ....................... 5
No. Component A1)
23– Side light, left ......................... 5
24– Windscreen washer system,
pump ...................................... 20
25– Heating, air conditioning ......... 25
26– Heated rear window................. 20
27– Rear window wiper .................. 10
28– Fuel pump ............................... 15
29– Engine control, petrol engine ... 10
30– Sliding roof ............................. 20
31– Automatic gear box.................. 20
32– Injectors: petrol....................... 10
Engine control, diesel.............. 15
33– Headlight washers................... 20
34– Engine control, diesel engine... 10
35– Trailer device connection layout... 30
36– Fog lights, rear fog light .......... 5
37– Contact ................................... 10
38– Boot light, Central locking/
39– Hazard warning lights.............. 15
40– Horn........................................ 20
41– Lighter .................................... 15
42– Radio ...................................... 15
43– Engine control, petrol engine ... 10
Engine control, diesel engine .. 10
44– Heated seat ............................ 15
manual in my sig mate if you need one ;)
Reactions: Mick288
steve carter
191
Poole, Dorset
sorted, i took a trip to a mechanic up the road this morning, got a fuse from them and now i have my interior lights, folding mirrors and my remote locking back.:) Thanks for the list of fuses lee, took me ages to find anything on the internet and not long after starting this thread there it is, should have come here first.
Gingerbread Man
172
Gloucester
Thanks Lee, just grabbed a copy of the manual which could be helpful. Thanks for the info regarding the fuses too, iv got 3 interior lights not working and if it were one I'd say perhaps bulb but 3 is a fuse I reckon. Someone previous has replaced a couple of the lights with LED ones so that might have caused the fuse to go.
The lights not working a the rear passenger seats and boot light. The ones replaced for blue led are in the front in the centre small lights either side of the main interior bulb.
Out of interest what would your thoughts be to the interior lights not turning off when I use the remote central locking with the key? Iv have the slider to the left most position on the main light. Could it be related to the fuse also?
Sent from my Nexus 7 using Tapatalk 4
