Inlet Manifold
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
I want to take off my inlet manifold to polish it. I think it would look wikkid. Is this an easy job?? Don’t look too hard.
All I can see me needing is a new gasket and the torque settings for the bolts.
Has anyone done this? How hard is it to take the injectors out?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Easy job if you take it steady. Pop a power gasket (insulating) on while you're at it.
Here's my new one waiting to go on (professionally done)
HarveyGTI
Easy job if you take it steady. Pop a power gasket (insulating) while you're at it.
how much was that to get done dpj?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Dave, what you think of it? He said that one for some reason was an arse to do. I think mine looks awesome.
Nice piece of work. I don't know how hard you looked at it, Phil... I can see where he's had real difficulty - but that's down to the casting - without reading this post I'd defy anyone to spot what's wrong with it in 10 seconds..... :shrug:
Funny, I'm 50/50 with the FMIC at the moment. Do I take the charge pipe outlet a la Ibiza and inlet as LC (leave my own inlet mani on), or do I run it like a Leon Cupra R (and use the shiny one)? Any thoughts?
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
For the op - if you're going to do it, get it done professionally. It'll mean getting hold of a spare and getting it sent away, but the difference will be worth it. I've seen some that have been done DIY and some that have been done on the car - not worth it IMHO.
They always look a bit minging with a polished manifold and unpolished throttle body, so you might want to think about that.
Dave - got to be easier to go Ibiza charge pipe style? Although don't they have problems with the turbo outlet hose (at least forge do a TT/S3/LCR one)? Perhaps one for your project thread, but there's a fair bit to source/change to go LCR style charge pipe. Have you got a single pass FMIC?
Edit: In fact, I'll reply to you in your thread.
kez
Jan 29, 2007
1,014
Dewsbury, West Yorkshire
i think you should let me buy the shiny one (assuming it's for an 'R' :confused: )
:cartman:
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Ok so how much for an inlet mani and a polish job??
Also how hard is it to take the big metal pipe off to polish that? (the one with the pic of a hand on it that runs roud the left of the engine (charge pipe???))
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
I was going to recommend GLM, but postage costs might now be a problem (they've relocated to Austraila!)
I think they quoted me £70 odd including pick up and delivery.
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
I think will get this and a inlet mani, try polishing them up myself !
got to try find in inlet mani now :p Might do charger pipe first and see how i get on.
How hard are charger pipes to get off?
