inHg at idle after dv change
ySoCereal
61
Not that long bought a LCR revo stage 2 with all the associated mods.
Put a badger 5 tip and bmc twin cone filter on the other day but still had a forge splitter dv on it and at idle it was sitting at -15 or so.
Today my forge 008 arrived (2nd hand) yellow spring in it, put it on and it's now sitting at -29 to 30 at idle. Under wot its boosting to 22-24 and holding about 18.
Does this all sound right? Never had a turbo before so learning as I go.
ySoCereal
61
Found a kinked hose - the one that has a 1 way valve leading to the long plastic probe thing that goes into the tip. Didn't notice it as it had a 3 button heat thing over the 1 way.
Fixed that it's now sitting at -25-26 though on idle. Is this normal?
hombre_paulo
157
My stage 1 LCR sits at around those numbers, as long as its not at something low like -15, or bouncing around you're probably ok
