where's the temp sensor located now?
i had the crank case pipe going to a breather, but i still had a thin film of oil over everything, so went back to drilled air box.
I've still got the power rohr, so might drill that and get something welded for the breather pipe.
One question is it rubbing on the brake fluid resevoir, I had a induction pipe made up of samco bit's and it wore through the silicone running against it?
its located between the air intake position at the headlight and the inlet of the bmc, seems to be ok just now need to wait and see....
