I've decided to go for a green open cone filter for my lcr, with an 80mm inlet and 200mm long. So to connect this to the intake I need to order a samco straight connector as well, should I go for 85mm diameter and use jubilee clips to tighten it or do I need 80mm diameter and stretch it a little to go over the neck of the filter and the intake? Is this everything I need, just the cone filter and the straight connector? and is the neck size correct?
Here is the link for the filter:
http://www.green-filter.co.uk/product_info.php?cPath=622_755_756&products_id=100088
and the connector:
http://www.green-filter.co.uk/product_info.php?cPath=696_692_650&products_id=100990
cheers
and the connector:
cheers
