Indicators gone mental!
panholio
333
Leeds
Ok dudes the indicators on my 03 LCR have gone mental.... :cry:
If I press the hazard switch they work fine but if I click the indicator stalk up or down I get nowt. No flashing on the dash just a horrendous buzzing/scratching noise from behind the hazard warning switch!
Help! :(
panholio
333
Leeds
I was thinking that. Or a relay gone beserk, how do I get to it? Yank the hazard warning switch out?
dj_hektik
LEON 20VT FR
i saw a guide once, i think on vwvortex, the guide was modifying the unit so you can use LED indicator bulbs - basically the guide was modifying the indicator module so they don't flash fast even if a bulb is burnt.
The guide shows how to remove the unit... search for indicator LED or something like that ... i can't remember anything else, sorry
Math
my indicators are going a bit mad as well at the moment, sometimes work and then quick flashing and normal flashing and sometimes you get no flashing on the dash and try again and you do.
hazards are slightly better but sometimes flash a little out of rythm and fast, it isnt the bulbs my diagnosis is the relay so going to order a new relay (hazard switch?) from seat tomorrow.
TheOtherSimon
454
There seems to be a spate of this at the moment - i've posted the same advice on three different threads now.
Your hazard flasher relay has died. It's about £35 for the switch/relay unit in the centre of your dashboard. It's a modified part from the original one - which was not up to the job and was actually subject to a recall in the US.
If the relay flashes at double speed - it means that a bulb has died. If it goes very fast or random then the relay has died.
The part number is in the other threads.
Simon
Math
thanks for the advice Simon, i read it and got your part no. on another thread so will put it up here as well:
Seat: 1MO 941 509B
JJFukkard
45
Guys,
I've had the same problem lately but I found a fix. If your indicators are flashing twice as fast as they should it's a warning that you have a bulb out. I found that my front indicator was working then not. I took it out today, gave the contacts a clean and a spray with WD40, put it all back together and it's fine now :)
Math
Guys,
i think on another thread it was stated that the problem you had is also quite common that the contacts lose their connection slightly and cause the indicators to flash quickly.
if its the relay the indicators will work,flash quickly or not work at all :)
ICUMonkey
Indicators
Ok, have a problem with my indicators too...
They work fine when I switch the hazards on but not when I indicate left /right.
Something wrong with the indicator stalk perhaps??
Any suggestions / advice on fixing?
Any help much appreciated....
:confused:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ignore hazards for now
activate left or right one at a time and check the 3 bulbs each side are ALL working properly
if they are and its still going crazy its most likely the relay
ICUMonkey
But i dont get any sound coming from behind the hazard switch.
That does sound like a relay going wrong but mine is just silent.
I'd like to think mine will just go away by itself but that might be a bit hopeful.
Kind of need my indicators now, for indicating....
ICUMonkey
When the hazards are on, all bulbs work fine.
When the hazards are off but I am indicating left / right, I get nothing. No lights inside or out.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
supply from or the indicator switch itself is worth a test with a multimeter then
TheOtherSimon
454
:confused:
I'd start with replacing the hazard switch/relay assembly. They are all off the same fuse, so if one works but the other doesn't then it sounds like the relay. If that doesn't work then try replacing the column stalk.
Simon.
ICUMonkey
Indicators
Thanks for the advice.
Replaced the hazard relay and now the indicators work a treat.
Back on the road..... [B)]
