idle revs up and down
Hailea3108
on idling my lc revs fluctuate up and down.
nothing major, can just hear from the exhaust the revs pick up a bit then drop and so on..
any common faults or obvious ideas?
R@B
I Like Turbos!!!
Mar 11, 2009
203
Sunny Glasgow
Could be throttle body, do you have the engine management light on? Try searching, the throttle body is a common problem which can sometimes be cured with cleaning. I wasn't so lucky, I had the same problem with the revs, my throttle body needed replaced but since it was just a slight fluctuation I didn't bother replacing it, think a new throttle body was between £150-£200.
Sent from my GT-P3110 using Tapatalk 2
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
first thing is first , irratic idle check all your vacuum lines (common the split under intake manifold) check hardware first before looking at electrical items
