ICE Installs
D-Power
110
Newmarket
Thought I'd start a thread to try and take care of some problems I've got and some others have had reading old posts.
Where have people earthed their amps?
Have you taken power from the top connections on the battery, or taken off the second cover and gone from the main terminals?
Routing of wires?
Interference?
Any other tips/tricks
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
i have earthed my amps/power cap to my seat belt buckle thing under the bold! the guy that installed mine originally took a feed straight of the top of the battery under the norm wires.... mine goes through one of the top right hand side holes (there might be a black cover over it) and yes there is interference with my speaker amp but not with my sub amp i dont know why as the wires go the same place so i disconected my speaker amp and ran the speaker straight from the Kenwood HU :) the wires go under the door sills...
dasmith83
Formerly "Dave FR PD130"
Jul 1, 2006
602
Kent
-amp is earthed to the standard earth point behind the side panels on the near-side of the boot
-power is taken from main terminal
-routing of wires:
1) power goes through two grommets on the far near-side of the engine bay, 1st takes the wire under the scuttle panel, 2nd takes it through to the inside of the car, and comes out behind the insulation stuff behind the near side of the dash (remove the near-side of the dash panel and you'd see what i mean). Power cable then goes down the near side of the car under the plastic trim (simply pull up to remove) and comes out in the boot
2) Remote and rca's both go accross the driver's footwell, and down the off-side of the car, again under the plastic trim and out into the boot.
-interference...none :D
gazjones
ive taken my feed off the bat terminal that has a second wire running off it its got a casptive nut and a spade end fits perfect on it . ive run my wires down the passenger side of the car through the bulkhead at the top right of the engine bay as you look at it then down under the sill trim to the back off the car. my rca's run just under the glove box from the head unit and under the sill trim again and ive earthed mine on that bolt as mentiuoned above but there are also earthing points for the lights on the boot( behind the carpet in thoses cubby hole type of bits at each side of the boot)
this shows where the amp power cable goes through the bulk head there is another hole behind this as well under the plastic trim under the wipers
gazjones
-routing of wires:
so you have got it all done then! its a pian first time ive done it 4 times now and takes me about 30 mins lol
dasmith83
Jul 1, 2006
602
Kent
lol oh yer, i knew i was meant to tell some1!! sorry gaz, i totally forgot...yer all is in and up and running! finally!...the sub itself took 2 weeks to arrive, but at least when it did i had the wires all ready.
gazjones
yes that is a good idea fiddle around for ages before then when you get it it takes 10 mins to plug in!
dasmith83
Jul 1, 2006
602
Kent
yep...and it literally did take 10mins! glad i took my time with the wires though, it all went in pretty straight forward
btw occasionally when the stereo turns on/off the sub goes "pop" sort of thing....hardly ever but very occasionally pretty loud! lol, not too bothered, just curious to know what is happening.
gazjones
that is the remote turning the sub on and off mine goes bump everytime i switch it on and off you might find the sub starts playing a fraction before the rest of the speakers turn on as well
dasmith83
Jul 1, 2006
602
Kent
ah ok...nothing too serious then. strange how none of my previous setups did this, maybe its an alpine thing
D-Power
110
Newmarket
Sub box, 6x9's and two amps all in now!
Took power cables though the grommet top right of engine bay as you look at it and then down running under sill on passengers side. RCA's run under centre console then go under passenger seat meet up with powers and go down side of rear seats.
No interference and so far and the only rattle is the parcel shelf-bit of carpet/foam and it'll all be sorted.
Ibiza02
324
North East
getting rest of mine fitted in about an hours time!!! so far have:
-2x12inch subs in imitation black leather box with white imitation leather inside the box with a mirror and a blue neon
-520 watt 4 channel amp (running speakers) (to be fitted today)
-1200 watt 2 channel digital amp (running subs)
-1.2 Farad powercap with blue neon and flashy led things in top (to be fitted today)
-17cm component front door speakers and tweeters
-alpine headunit
-FM modulator
-2x38cm blue footwell neons (to be fitted)
-cab light going to change to blue bulb
-boot light change to blue bulb
GOING FOR THE BLUE EFFECT LOL:D
will people post some pictures up of their installs? i will put some of mine up once its fitted...
cheers
chris
lukey
4 Ringer
Sep 28, 2006
327
Harrogate
-routing of wires:
exactly the same as my routing, zero interference for me too
SWANSWAY CUPRA Dealership
