Having problems with my Ibiza TDI 130 that i purchased last week from a dealer about 50 miles away. After 4 or 5 days it conked out going round a roundabout, on the way out of the roundabout i applied the accelerator and there was nothing. It was in 3rd gear and i was doing around 20-30mph (big open roundabout). I had to stop and put the hazzard lights on and try and start it again.
It started again after 3 or 4 attempts and ran perfectly again until saturday, when it gave up on me on the shore road. I was in a line of traffic and someone was turning right into an industrial estate in near my house. I slowed to a stop with the clutch pedal right in, and took it out of gear, whacked the hand brake on, and then when i went to move off i realised it had conked out again.
I never felt anthing either of the two times like you would if you stalled a car or anything. It wouldnt start again so I had to get it towed, and when being towed it started again when put into gear. I took the car up to a friends house who has a VAG COM later on and on the way there it gave up when i came to a stop again because i got a telephone call. Luckily i was on a hill, so i rolled down building up speed and put it into gear and got it started again. On the way into my friends street it died on me going round the corner in 2nd gear, so i had to push it the last 200 meters or so! It wouldnt start at all standing still...
Luckily my friend knows a bit more about cars than me, and he put it into 1st gear, made it tick over... it chugged... then started. Really weird problem, because the only relevant error showing up on the VAG COM is:
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Any ideas or help much appreciated! I hope someone knows of a common fault with a silly sensor or something?
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
