Ibiza TDI 130 problems... Help / advice needed!
FoZz
69
Having problems with my Ibiza TDI 130 that i purchased last week from a dealer about 50 miles away. After 4 or 5 days it conked out going round a roundabout, on the way out of the roundabout i applied the accelerator and there was nothing. It was in 3rd gear and i was doing around 20-30mph (big open roundabout). I had to stop and put the hazzard lights on and try and start it again.
It started again after 3 or 4 attempts and ran perfectly again until saturday, when it gave up on me on the shore road. I was in a line of traffic and someone was turning right into an industrial estate in near my house. I slowed to a stop with the clutch pedal right in, and took it out of gear, whacked the hand brake on, and then when i went to move off i realised it had conked out again.
I never felt anthing either of the two times like you would if you stalled a car or anything. It wouldnt start again so I had to get it towed, and when being towed it started again when put into gear. I took the car up to a friends house who has a VAG COM later on and on the way there it gave up when i came to a stop again because i got a telephone call. Luckily i was on a hill, so i rolled down building up speed and put it into gear and got it started again. On the way into my friends street it died on me going round the corner in 2nd gear, so i had to push it the last 200 meters or so! It wouldnt start at all standing still...
Luckily my friend knows a bit more about cars than me, and he put it into 1st gear, made it tick over... it chugged... then started. Really weird problem, because the only relevant error showing up on the VAG COM is:
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Any ideas or help much appreciated! I hope someone knows of a common fault with a silly sensor or something?
FoZz
69
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
Yella Beeza
Now which way?
Jun 4, 2007
497
Edinburgh
Im only guessing because I'm not familair with VAG.com, but could it be either negative/earth lead not properly tightened on battery, or it's not earthing properly to the body? Tis could explain intermittent low voltage.
Tom B
4,710
16
Northampton
Bad engine earths can kill the engine and electrics as soon as it comes detached from its grounding point.
Its not one I've heard of before in my many years of MK4 Ibizas, but bad earths could be the cause.
FoZz
69
Thanks Tom B. Do you think if that was the problem the other things, such as lights etc, would be affected? Because I dont recall the lights or other electronics turning off?
I dont really want to have to hand the car back to the dealer is it something as simple as that, so i am going to get my local mechanic to have a look at it tomorrow and see if there is anything obvious such as that. If not, i will be leaving it back to the dealer i bought it from, as it is unsafe to drive with this intermittant problem.
If there are any other ideas, or people can confirm what has already been said please let me know. If not, i will post back as soon as the problem is identified for sure.
FoZz
69
Think she's back on the road guys. I have drove down to the republic of ireland in it with a full tank of high octane stuff from BP, "BP Ultimate Diesel". Has ran fine really, although i noticed slight hesitation twice over the 200 mile journey. I have a funny feeling its been water that gave me the trouble, and although i am no expert, the symptoms make sense.
On the way home I had no hesitation from the car at all and havent had any problems since. So i am nearly 100% that bad fuel was to blame!
NAMED AND SHAMED: Jet Filling station, shore road, newtownabbey, county antrim, northern ireland.
FoZz
69
Full service done on the car now. Seems to be running ok. Some really dodgy merchants about these days. Putting all sorts in their fuel to water it down to make an extra penny or two!!!
RUM4MO
7,966
1,059
South Scotland
Well you did mention Jet - over here in Scotland I think that they have vanished - well from any sites that I was aware of - and yes back in the "80s" and "90s" they were all well known for giving you free water in the fuel - maybe something to do with maning them mainly with school kids and other cheap labour - and carrying out no maintenance on the tanks.
CHR15B
2,567
9
Scotland
Funny you say that... There was a Jet station in Paisley and a few of my friends had various problems with their cars that they eventually narrowed down to being the fuel from there.
Since I started driving TDI's... I've serviced on the button, used Shell Diesel Extra and always used OEM Parts/Quality oil and never once had a problem in over 80K.
FoZz
69
happy days, thanks for the info people. note to all then, steer clear of Jet filling stations then... literally!!!
EdButler
713
Sheffield
If it ever happens again check the coolant temp sensor and crankshaft position sensors. Common faults on VAG cars and often cause random cut-outs.
FoZz
69
Oh Dear guys... 9 months on and it happened again on friday night!!! This time i really dont think its dodgy diesel. Thinking logically i think its either a fuel system problem, or something silly electronically, because i have done 185 miles since the last fill up, which was BP Ultimate Diesel from a relatively newly built garage. If it had of been water in this i would have seen the symptoms before now as water would normally sink to the bottom of the tank.
I have also just had a service carried out about 50 miles ago, on Tuesday past which is strange too, because a new fuel filter was fitted, so everything should be nice and clean.
I was turning into a left hand junction at about 15mph in second with the clutch pedal fully released, didnt hear the engine knocking off or feel any normal signs of stalling (which it shouldnt have anyway) and she wouldnt start again.
After 20 mins or so trying to start it and getting the tow loop out for the front, i stuck it in first and started it with the clutch out to chug it up onto the kerb for the night, and as soon as the back wheel moved over the small kerb lip the engine started.
Strange and annoying. Any further input much appreciated guys.
FoZz
69
just got the diagnostics ran there with the following results:
Monday,06,July,2009,19:54:55:21552
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ########## Mileage: 109580km/68089miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 LA
Component: 1,9l R4 EDC 0000SG 5405
Coding: 00102
Shop #: WSC 06402
VSSZZZ########## SEZ7Z0C##########
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V40
Coding: 00188
Shop #: WSC 06403
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
6 Faults Found:
00797 - Sunlight Photo Sensor (G107)
007 - Short to Ground - Intermittent
010 - Open or Short to Plus - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
01273 - Fresh Air Blower (V2)
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0E AIRBAG VW5 07 0008
Coding: 12357
Shop #: WSC 06401
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 920 K
Component: KOMBI+WEGFAHRSP VDO V12
Coding: 00445
Shop #: WSC 00000
VSSZZZ6LZ4R148262 SEZ7Z0C2322608
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 62 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: J2 Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
Part No: 6Q1959801A
Component: J2 Tõrsteuer.FS KLO 0202
Part No: 6Q1959802A
Component: J2 Tõrsteuer.BF KLO 0202
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6L0 035 156 B
Component: seat s04 GRO 1 98
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
29-10 - Short to Ground - Intermittent
End ---------------------------------------------------------------------
Wingnut_Kiteboy
Battery Charged ?
Silly question, when the car packs up, is the battery flat, or charged OK.
FoZz
69
Seems fine to be honest. When i chugged the car forward in gear to get it up a slope on the footpath to move the car up on the kerb the car started, so surely if there was a problem with the battery it wouldnt have the power to chug forward would it?
