ibiza rear speakers
Rader
hello
I have a 1999 ibiza, and I am currently trying to connect some speakers to the rear of my car, the wires are already wired into the car, they are coloured blue and brown, both have stripes, which one do I connect to the Positive of the speaker, and which to the negative?
Viel Dank
Josef
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
Pretty sure the brown will be negative. In any case, it's not going to make a massive amount of difference if you connect both rear speakers reverse polarity. It's when you wire the two speakers out of phase (i.e. one correct, one reverse polarity) that you'll start having bother. And even that's nothing too serious, you'll just be a little lacking in the bass frequencies.
Rader
thank you
I though the brown would have been positive, but I think you are right, as the negitive earths on the car are brown.
thanks for your quick response:)
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
gunna be gettin some 6x9 for christmas, so does everyone just cut the plug off the stock rear ones and use that wire on the 6x9's?
or do you get better sound if you run a new cable back there?
Chris
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Rule of thumb I always go by is that if u turn the speaker upside down and look at the writing the +ve is always on the right.
My big bro use to make speakers and thats what he told me years ago lol.
hopkinsgm
May 25, 2001
2,030
...does everyone just cut the plug off the stock rear ones and use that wire on the 6x9's...or do you get better sound if you run a new cable back there?...
If you're running them direct off the head unit, you might as well just use the factory wires - the current handling is adequate for the sort of power most head units are capable of kicking out. Make sure the head unit will kick out enough grunt though - there's nowt worse than the sound of an amplifier being run to the point of overdrive just to get a speaker moving. And it's an excellent way to break the speakers too. Probably as many speakers get knackered that way than by overdriving the speaker with an overpowered amp. If you're planning on using a separate amp, run some fresh cables tho.
Bentley1989
Mk2 Ibiza 1.4s
Dec 18, 2007
343
Hartlepool
cheers for that man
ive got a 50x4 head unit so its quite good, got loads of EQ stuff on it too
not gettin anything expensive just some sony explod components and 6x9s :)
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
cheers for that man
Should be fine running that mines a Panasonic MOSFET (whatever that means) 50x4 watts and its has plenty of juice for JBL's, probably a bit too much still at the higher volumes!
Dave_R
Sep 20, 2004
3,666
South Wales
Metal Oxide Semiconductor Field Effect Transistor :p
Basically better components to amplify compared to normal transistors, most CD players use them these days!
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
Just I be a smart arse, most amps use them not cd players :) (20years a electronic enginer :whistle:)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i'll add that to my memory list
used to use a 9v battery and see if they warped out or in :whistle:
Dave_R
Sep 20, 2004
3,666
South Wales
I did state the amplify bit hehe :whistle:
I meant most CD Players have written on them MOSFET...... (electronic engineer just out of my apprenticeship) :happy:
ChrisGTI
ive got a pioneer head unit, powering 2x vibe 6x9's using the standard wiring and it sounds fine!
