Ibiza MK4 Sport/FR Boost Pipe Issue :)...Solved!
Seat_Stu
277
Hey,
Thought id write a small guide to this as its common and happened to me 'yet' again!
On the PD130 engines like mine you may come across this annoying problem.
You hear a loud bang? Lose loads or nearly all power?
You have a side mounted inter cooler (SMIC) located above the left wheel, in the arch. You can just see it if you look down behind the headlamp.
There is a pipe which comes down from the left side of the engine (showed in the image, the left highlighted area) which goes down and clips into the SMIC. There are 2 sections of this pipe, giving it 3 possible places it can break apart.
Its poorly designed and basically, one pipe goes into the other, the pipe which enters the other had 2 metal lugs on each side and on the surrounding pipe there is a metal clip which goes around holding it in with these 2 metal lugs. (shown below in image)
In this image you see that this metal 'lug' had worn off and opened up a hole in the piping giving away my lovely boost to power!!!
I shall check pricing of this pipe when I see the receipt at home but from what I remember it was around £20 for a new section of pipe, the corner section, and £1 or something for the metal clip!
Hope this helps people understand the problem if they have this, could make it a sticky if you want !
Stu
Thurman
103
This has just happened to me! I was considering a forge silicone jobbie but its approx £60! By any chance do you have the part number?
Seat_Stu
277
you want the official pipe part number or a forge one?
I think ill only be able to find the official VAG one.
Stu
Thurman
103
Stu
The VAG part number would be great. My local dealer is awfu,l it would probably take them a week to find the correct part :censored: shambles!! Was it £20?
Cheers Stu.
Seat_Stu
277
right on my recipt it just says the following...
Parts Used:
6QO145769 Clip = 0.62 + VAT
6QO145834D Hose = 19.96 + VAT
I hope that helps!!!
n11tht
278
under the bonnet
i may be having the same problem as this want to take the pipe to have a look, do the metal clips holding it in place break when you take them off? there being a bit stubborn to come off
Seat_Stu
277
I never took it off but i dont think they should break, as how would you get them or a new one back on again! :D
Thurman
103
