Seat_Stu
277
Hey,
Thought id write a small guide to this as its common and happened to me 'yet' again!
On the PD130 engines like mine you may come across this annoying problem.
You hear a loud bang? Lose loads or nearly all power?
You have a side mounted inter cooler (SMIC) located above the left wheel, in the arch. You can just see it if you look down behind the headlamp.
There is a pipe which comes down from the left side of the engine (showed in the image, the left highlighted area) which goes down and clips into the SMIC. There are 2 sections of this pipe, giving it 3 possible places it can break apart.
Its poorly designed and basically, one pipe goes into the other, the pipe which enters the other had 2 metal lugs on each side and on the surrounding pipe there is a metal clip which goes around holding it in with these 2 metal lugs. (shown below in image)
In this image you see that this metal 'lug' had worn off and opened up a hole in the piping giving away my lovely boost to power!!!
I shall check pricing of this pipe when I see the receipt at home but from what I remember it was around £20 for a new section of pipe, the corner section, and £1 or something for the metal clip!
Hope this helps people understand the problem if they have this, could make it a sticky if you want !
Stu
This has just happened to me! I was considering a forge silicone jobbie but its approx £60! By any chance do you have the part number?
you want the official pipe part number or a forge one?
I think ill only be able to find the official VAG one.
Stu
Stu
The VAG part number would be great. My local dealer is awfu,l it would probably take them a week to find the correct part :censored: shambles!! Was it £20?
Cheers Stu.
right on my recipt it just says the following...
Parts Used:
6QO145769 Clip = 0.62 + VAT
6QO145834D Hose = 19.96 + VAT
I hope that helps!!!
i may be having the same problem as this want to take the pipe to have a look, do the metal clips holding it in place break when you take them off? there being a bit stubborn to come off
I never took it off but i dont think they should break, as how would you get them or a new one back on again! :D
