Ibiza Fr Tdi *Updated 24/09/10 Mass mods
Alex 17
No Smoke No Poke
Aug 17, 2008
1,920
Bedale - North yorkshire
nice car i really like what you have had carried out on the car and its a bit different to the usual. have you thought about getting the bit behind the front number plate done in carbon fibre?
i told you that you should do that ages ago in your thread :rolleyes:
Ooops! Must of missed that ! I'm on with it now anyway :p , quite hard with it been so low down on mine!
Any chance of you posting some close up pics of your difuser sarah? Like in the corners near the top etc , did they remove it or do it on the car? As in is the carbon cut around the lines or pushed behind through the gaps?
Ps: you need carbon on you're front S , if you need it doing send it may way and ill sort it out :)
Sarahfr
Sarah
Mar 24, 2010
39
Manchester
I'll get some more pics at weekend, as it's dark now when i'm getting home from work
I don't think they've removed it as it looks to be in one piece, but it goes right the way under the car.
I've ordered a debadged grill to see if i like that, if not i will be carboning the original 'S', or the other half will be for me.
I'm thinking of doing the mirrors, not sure yet though.
Alex 17
No Smoke No Poke
Aug 17, 2008
1,920
They removed it from the car, because when i called to see it round at the garage (it went in for mot aswel) i was like what's happened to the rear of it :doh:
There is a join, but only visable if pointed out.
Hmm , how do you rememove them? I thought it was plastic welded!
Sarahfr
Sarah
Mar 24, 2010
39
Manchester
What have you got planned next when your piggy bank is full again?
WHEN my piggy bank is full again, that will be sometime off :):):)
Not sure what i'm going to do, i'm trying not to think about it at the moment
Only had the car 6 months & spent a fortune on it
Alex 17
No Smoke No Poke
Aug 17, 2008
1,920
Haha ok :p
Was just looking at mine , could not decide if i should try tuck it behind the plastic or try get a smooth cut along the edge , Thats why i asked how they did it on yours :)
Sarahfr
Sarah
Mar 24, 2010
39
Manchester
Haha ok :p
Tbh i think it's pushed through the gap, will have a look in day light and let you know :)
Alex 17
No Smoke No Poke
Aug 17, 2008
1,920
Thanks :) , Can remove it by useing a heat gun too melt the plastic welds anyway im told ,then use more plastic too put it back together, so may do that :)
Looked quite a hard job too cut it so may have too tuck it behind if i can
Sarahfr
Sarah
Mar 24, 2010
39
Manchester
I've found a better pic of the diffuser, and asked the man of the house how it's been done :D
It's been done in a couple of pieces, but you can't tell unless you get on your hands & knees to look at it.
As you can see from the photo it's trimmed right up round the number plate lights.
Hope this helps :):):)
Alex 17
No Smoke No Poke
Aug 17, 2008
1,920
Ahh that explains , so it just runs up and over the top edge onto the ''roof'' of the deffuser where the lights are so theres so ruff edges?
Where has it been cut into sections? I planned on doing mine in 1 peice =/
Sarahfr
Sarah
Mar 24, 2010
39
Manchester
The piece under the car is joined below the number plate, then that top half is in one piece.
Like i say you can only see the joins if you get down on your hands & knees looking.
Good luck with yours, get some pics up when you've done it :)
