Ibiza clutches
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
sorry boys not really up to scratch with my transmission knowledge...been reading on "how stuff works" to understand how clutches work lol
gonna be leaving it till my 60k service is done anyway which is 7k away but doing the research now...dont hear of many ppl bothering though
so an upgrade is ideal but not looking to spend hundreds more than a standard kit
Nov 2, 2004
9,335
South Wales
Karl, have you got any problems selecting gears?
I had this problem and it seems to be something to do with the master cylinder, if i put my foot behind the pedal and pull it out now and again i dont get the slipping problem.
acidstrato
Dec 9, 2004
5,942
nah no problems with gears at all, just revs rising like **** once it hits 3.5k
strangely though its not happening every run. car doesnt feel slower by any means neither, just sorta annoying
Jun 29, 2001
537
Surrey
This is what happened to mine too. Car is on 80K now, chipped (+ KO3S) since about 50K. Clutch started slipping every now and again. My flywheel ended up knackered so I ended up buying the Spec Stage 3 clutch from JBS. SEAT wanted £650 for a new clutch/flywheel assembly. Couldn't justify buying it as I knew it would just slip again (see sig below for torque car is producing). It was ok most of the time when on low boost (around 250lb ft) and didn't slip but the clutch couldn't handle the high boost setting. The Spec clutch cost an extra £150 over the OE kit but I can't fault it. Very stock feel, lovely to use and it GRIPS!!! I looked at a couple of the more popular upgrades (Sachs etc) but the torque rating they gave didn't fill me with confidence, although the price for these were a lot cheaper than the Spec clutch. I may have paid over the odds for the Spec clutch as I was in a hurry for it (car was off the road for a month of Xmas) but JBS may be able to reduce the cost, depending on how many they order.
Hope this helps.
Damo
Ibiza sport man
155
Kettering
Anybody know if the 130/160 PDI clutches can be used on the 20VT engines and if they have a higher torque capability ?
I am looking at the Sachs kit part number 3000 846 201
Bernard
