Shivy
Hi,
I have an Ibiza 58 Ecomotive. My wheels need to be aligned, as I'm having a Camber problem and the tyre threads are being eaten one from inside, the other outside.
However my local garage said some car cannot be Camber adjusted as the direction bar does not have the adjustment bolt, etc. So may need a new bar if this one is bent.
Can anyone tell me if my car model can be Camber adjusted without changing any parts ? or will I have to change that/those bar(s) if cannot ?
Thank you
best regards
Shiv
Thank you
best regards
Shiv
