Hub Carrier
Jun 26, 2008
849
Sunderland
I need a new hub carrier and am just wondering if buying a second had one is ok or if a brand new one is needed? :)
Also would my current hub flange/wheel bearing assembly be easy to press into the carrier
or will i need a press?
Done a quick search but cant seem to find a definitive answer :(
Cheers in advance :D
James.
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
I deffo have some. You will need to press out your old hub and fit a new wheel bearing as well as it will split apart when you press out the hub. PM me if you need the carrier.
