How to Turn up the fueling...?
Cupra_Jeff
126
Kent
Mine is running a wideband and doesn't go above around 11.8 - 12.0 on wide open throttle....
mainly around 11.0 - 11.5 range
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
My car is running really lean and need to turn the fueling up, any ideas?
What AFR do you run??
most lean running is caused by under reading MAF.
how are you judging yours is lean?
12:1 is usually best power, but common to run a bit richer for cooling issues.
