how to replace the knock sensor?
flashbsd
ANybody know where the knock sensor is in relation to being able to change it?
Seems mine has thrown faults up while in the garage, any idea on location and price would be grateful :)
Jonzy
Look under the inlet manifold and youll see a bracket with i think 3 multiplugs on, follow the 2 identical ones... youll see the sensors bolted to the block.
flashbsd
ah i had to move those to fit the oil temp sensor in top of the housing, i assume they are pretty easy to replace then :D
The timing on vag-com pulls back when sittign in neutral and blipping the engine, even with a stock ecu etc.
Well nothing at the moment, but i will look at this.
