How to replace fuel temp sensor
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
Basically had the EML light pop up on the dash.
Did a VAGcom error check and it came back with 17571 - Fuel Temp Sensor (G81)
Open or Short to Plus. I cleared the code but it came back again this morning, this was after a 40 minute drive to work with 10 mins at 70mph on the motorway.
I think I've found the sensor but can't see anyway of unclipping it. How does it disconnect?
Ta
muddyboots
Still hanging around
Oct 16, 2002
5,739
On the Mk4 Ibiza TDI, it's in the fuel line; standing at the front of the car and looking at the engine with the cover off, it's towards the right-hand end (ie passenger side) of the head, on the front. Has a small plastic wiring connector going to it.
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
I think I've loacted it, just it just pull off or does it need unclipping? It looked like there was a clip there but I couldn't see how to get it off.
MJ
5,508
14
Manchester
Make sure the wires are not broken first mate.
Open circuit fault tends to mean a broken wire but its not uncommon for the sensor to just give up.
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
Everything seemed ok when I was looking at the wiring. Will clear it again today and get the proper reading from VCDS, as I can't recall if it was an inconsistent fault or intermittent fault.
