how to remove headlight switch
stevo72
151
cambridge
Hell guys,
I have a faulty headlight switch, the usual thing front fogs come on when head lights on, i assume there is not a way of repairing it ? have to replace it instead ?
I cant see how to get the switch out of the housing, I have taken out the surrounding plastic which then leaves the switch itself which i cant see how to take out, any advise would be grateful.
ta
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
If you're canny enough you can pull it apart and sort it, it's usually these metal prong things inside needing bent back to position as they tend to droop with age. A bit like granny tits :D
stevo72
151
cambridge
still no luck getting the switch out, been pushing it in, turning, pullling out as per abve and nothing....pull any harder and i reckon the console will come away with it!! i have disconnected the wiring from the switch but still no joy.....any more help would be appreciates
stevo72
151
cambridge
Did you get it fixed or just out ?
Fixed it thanks, took it out , took it apart as much as i could and then put it back together again making sure its all tight and that was it, all done pretty easy , one of the small things i am putting right before i sell the car :)
