How to get off cabin air filter door? Clips aren't accessible
Sep 13, 2020
19
How do I get the cabin air filter door off? All photos and videos I find have the clips visible and easily accessible, but as you can see from my photo they aren't in any way accessible. They're hidden behind a piece of plastic I can't remove.
I've tried flat head screwdrivers and other plastic tools, but I simply can't get anything in there at an angle that works. They're right up against the plastic in front. From videos I've seen some will bend the lower tabs, but I don't want to risk this in case they break and the door no longer sits properly.
Do the repair shops use some special tool with a 90 degree angle or something similar? Is there a smart trick to get it off?
cairus
1,192
431
3 noses to push away. long small flat screwdriver. is usually self-explanatory
cairus
1,192
431
Are there no instructions on the inside of the packaging for the new filter?
TheSwede
364
206
Sweden
Look like mine Cupra 2018. As "cairus" write, pry with a small screwdriver. If needed at the same time pull out with narrow pliers.
My Golf 2018 is easier to reach, no hinder there, same door/ solution.
cairus
1,192
431
you can't break anything. You have to work with a hammer and chisel
