How Much To Supply And Fit Pedal Box??
CUPRAAAAAAAAHHH
Found my trouble to be the famous crap box so what i need to know is how much should a dealer charge to supply and fit along with a new clutch cable also any good garages in the midlands that could do this??? thank you
CUPRAAAAAAAAHHH
Brummy said:
dood, why not do what I did... drill it, but a lock bolt thru..? been ok for nearly two years now!!:)
Can this be done without removal (i'm a bit cr@P with spanners hence the garage bit) thanks for the answer:)
