How Low...
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
Following on from the Mk3 Ibiza's thread, how low are the mk2 boys sitting and on what rimmage size, coilover or spring set ups?
*measure from floor to wheelarch through the middle of your centre cap*
mine ... sat at the moment at 560mm front 590mm rear on a Gmax Spring/shock setup , running at the moment on 15" BBS Ra's, but soon be changing to Borbet A's (again 15's) and possibly a coilover set
:blink:
So........... lets see ya :D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
205/40/17" = 596mm diameter overall
eibach springs + Boge o.e.spec shocks
610mm FR 620mm RR
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
slippers check
pen torch check
pipe lit / smokes - nope sorry given up 4 months or more now ;)
time taken doubled as im 2 stone heavier and chewing hard to kick my jelly baby addiction :p
mines standard so thats my cop out
be a good yardstick then ? ;)
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
'99 8v cupra sport / standard suspension 60k miles
185/55 15's = 584.5mm diamater
front 640mm rear 630mm
f*** it's dark out there! where's me cocoa?
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
im too embarrassed to say at the moment!! mine will give my touareg a run for the money its so high!:hide: but all in good time. got the bits to lower it just need some good weather to do it.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
On my 1.9tdi on standard shocks + springs 640mm Front and 630mm Rear. 185/60/14 tyres so thats 577.6mm rolling radius on the wheels.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
as i am really sad i've stuck it in a spreadsheet to see what differences are from tyres to arch height etc
interesting that the tdi + 8v both standard have the same ride height with different wheel sizes
be good to add some more on there
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
theres only 3.5mm difference in wheel radius between 8v and the tdi though fl@pper thats what will make the heights that similar, My 640 wasn't the most acurately measured in the world so 3.5mm could just be discrepancies in measuring. Plus the sag etc over time. Anyone got a standard height valver?
old 'uns
Mar 20, 2003
1,627
walsall
we'll be needing wheel centre > arch measurements as well then as a more accurate way of measuring drops?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
it was interesting as it was so close for a tdi + effectively sports suspension, i knwo we are not talking mm perfert but i'd have thought a cuprs would sit a bit more lower standard
mind you as you say age/sag/use/tread etc can all put it out a little
dont worry about wheel centre measure as i can get the diameter from the tyre size and if i use the same source for each one it will have some form of constant i guess
main thing is to remind DPJ it's time for Brucie !!!
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Remember to use wheel radius not diameter when comparing Fl@pper as that is the only thing that affects body height, the diameter would be showing double. But looking at vag cat the ABF and AHU AGG etc all use the same springs, i thought the TDI used the stronger springs and that confirms it. Although the tdi on parkers claims to be a bit lighter than the abf too. But the dampers are different between the petrols and the diesels. Thats where the sportier suspension comes into it.
