jonathanp
736
Coventry
I recently bought a replacement PCV valve as I suspect mine is faulty but when checking the new valve it seems that air will flow freely on both ports either when in vacuum or under boost, from reading previous posts on another thread this shouldn't be the case. Can anyone clarify?
As an engine runs, the crankcase (containing the crankshaft and other parts) begins to collect combustion chamber gases which leak past the rings surrounding pistons and sealing them to the cylinder walls. These combustion gases are sometimes referred to as "blow by" because the combustion pressure "blows" them "by" the pistons. These gases contain compounds harmful to an engine, particularly hydrocarbons, which are just unburned fuel, as well as carbon dioxide. It also contains a significant amount of water vapor. If allowed to remain in the crankcase, or become too concentrated, the harmful compounds begin to condense out of the air within the crankcase and form corrosive acids and sludge on the engine's interior surfaces. This can harm the engine as it tends to clog small inner passages, causing overheating, poor lubrication, and high emissions levels. To keep the crankcase air as clean as possible, some sort of ventilation system must be present.
cheers, thanks for the info, do you know how the PCV valve operates? It looks as though its supposed to seal but I can blow air in or suck air out on either port without it sealing
Should the intake manifold's pressure be higher than that of the crankcase (which can happen under certain conditions, such as an intake backfire), the PCV valve closes to prevent reversal of the exhausted air back into the crankcase again. This is where the positive comes from in the name. Positive is basically a synonym for one-way.
It is critical that the parts of the PCV system be kept clean and open, otherwise air flow will be insufficient. A plugged or malfunctioning PCV system will eventually damage an engine. PCV problems are primarily due to neglect or poor maintenance, typically engine oil change intervals that are inadequate for the engine's driving conditions. A poorly-maintained engine's PCV system will eventually become contaminated with sludge, causing serious problems. If the engine's lubricating oil is changed with adequate frequency, the PCV system will remain clear practically for the life of the engine. However, since the valve is operating continuously as one operates the vehicle, it will fail over time. Typical maintenance schedules for gasoline engines include PCV valve replacement whenever spark plugs are replaced. The long life of the valve despite the harsh operating environment is due to the trace amount of oil droplets suspended in the air that flows through the valve that keep it lubricated.
Not all gasoline engines have PCV valves. Engines not subject to emission controls, such as certain off-road engines, retain road draft tubes. Dragsters use a scavenger system and venturi tube in the exhaust to draw out combustion gases and maintain a small amount of vacuum in the crankcase to prevent oil leaks on to the race track. Small gasoline two cycle engines use the crank case to compress incoming air. All blow by in these engines is burned in the regular flow of air and fuel through the engine. Many small four-cycle engines such as lawn mower engines and small gasoline generators, simply use a draft tube connected to the intake, between the air filter and carburetor, to route all blow by back into the intake mixture. The higher operating temperature of these small engines has a side effect of preventing large amounts of water vapor and light hydrocarbons from condensing in the lube oil.
