how do i use vagcom
meltonlad
391
huntingdon
hi peeps ive just been looking on fleabay and saw that i can get a usb vagcom with drivers for about £14 but if i was to buy it could i use it on my 2000 toledo 1.8 20v ? is it easy to set up and use ? will it work on my vista laptop ?
meltonlad
391
huntingdon
yes it says works with vista. check it out what do you peeps think ? item number230335003811 is this the one i need ?
The reason i ask is that i got one of those leads and got the shareware from ross tech but it won't do a full search, only the first two blocks, and then it says it can't continue due to not being the full version.
