I have the digital climate but there is no air con button.now its starting to get warmer I've thought about it. How do u know when its on?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
slightly off topic, if it stinks, what should i do?
I thought that these Seats has not got Air Con but has Climate Control?
so when you push the econ button,
your a/c is on??
didnt now i had a/c....?
the coldest stand is LO on the screen...
A) you do have aircon, but its all wrapped up in the Climatronic system which, as mentioned, is climate controlled e.g. will track to a specific temperature.
B) ECON Mode = Air Conditioning Compressor Off, i.e. aircon off. However as techie mentions, there is no physical decoupling of the air conditioning compressor from the engine, so presumably some component of the compressor is always spinning. Quite how it stops producing cold air, I don't know, but one presumes that it is some other component which can be controlled electronically (perhaps a pump) which is turned off so that the air con gas stops circulating.
Slightly off topic, but is it easy enough to get rid of the gas from the a/c system as I am thinking about ditching the a/c core out of the way of the intercooler.
Unless you want to lose the refrigerant I think you'll need specialist equipment. A/C service/fridge companies drain the refrigerant back into a tank if they need to work on the system. There are two valves on the A/C pipework under the bonnet - they hook into these and pump the gas out - not too sure how - on fridge vans I think they just run the fridge system and let the pump push it out - I would guess it's the same on A/C
