How do I check my DPF level on VCDS?
TI KUFF
83
Can't seem to find the section on VCDS where it gives you the data of your cars DPF levels & how much is blocked.
Seen on Ross Tech forums '01 engine then 08 measuring blocks'.
But the problem is '08 measuring blocks' is blank, I can't click onto it.
Does that mean you can't measure DPF levels in Leons using a VCDS?
I have a 2011 Seat Leon 1.6 Eco Motive
