I think this might be your
problem.
If one of the brake fluid tank chambers empties completely (for example, due to a leak in the brake system), then an initial purge must be made on the hydraulic system.
Initial purge
– Connect the brake bleeder -SAT 1175B-.
– Open the air purge bolts in the order described and make an initial purge of the brake pads.
1 - Purge the front left and right brake callipers simultaneously
2 - Purge the rear left and right brake callipers simultaneously.
– While the hose of the collection bottle -SAT 1175B/1- is connected, leave the purge bolt open until clear brake fluid without bubbles comes out.
Purging
– Connect the Central diagnosis system -VAS 5051B- or central diagnosis -VAS 5052- to the vehicle adapter,“Selection function / component” → Chapter.
– Then:
– “Running gear”
– “Brake system”
– “01 - Self-diagnosis systems Mark 60/Mark 70”
– “03 - ABS/EDS/ASR/ESP Mark 60/Mark 70”
– “Functions”
– “Basic adjustment/brake purging”
– Once the purging process has finished, turn off the ignition and release the diagnostics connector.
Hope this helps.
