HighlyEvolved
or do all come standard with anti-lock braking system?
How old is it?
When you turn on the ignition, 2nd click before you fire the engine, all the check lights come on. I think there's an ABS light amongst them IIRC.
However all passenger cars after a certain date must have ABS as standard.
Another way to test is hammer down an empty straight road and hit the anchors fairly hard, the ABS normally gives a vibration through the pedal when it activates, although this is much less marked in newer cars than ones made ten years ago, plus you will find yourself not skidding into the hedge if you have ABS.
my 1.2 didnt have it but i was told they all did think all but the 1.2's wil have it though!
Do what I did the other day. Try driving along in three lanes of cars all doing 70mph in torrential rain and blinding spray. Then indicate and move over to the inside lane only to discover that the cars infront are all applying their brakes. You'll soon discover whether you've got ABS or not!:D
Go to an isolated back street.
pour two buckets of water on the road.
reverse your car at least a hundred metres away.
accellerateand brake hard on the puddle of water.
if you get a juddering vibration feedback from the pedal then you have abs.
Am I right in thinking that some of the clonks and thumps from the brakes when I am manoeuvring out of my parking space in the morning are the ABS unit checking itself?
Or is just because it's a SEAT?:)
It should perform one quick selftest when the car first goes over a certain speed (can't remember exactly what, IIRC somewhere below 10mph).
