horrid wiring
raepaul
71
well i noticed i had a few lights out the other day so went to change them, i thought it was weird as it was tail, sidelight and brake light but al just on the driver side. put in new bulbs and switched the lights on and guess what..... pop. they blew again.
anyone have any ideas? diy job or take it to a auto sparkie?
car is a mk3 tdi 90
any help appreciated
Daymo
Low and Slow..
Jul 22, 2008
428
Scarborough/Sheffield
car is a mk3 tdi 90
try checking your fuses mate, they may have blown.
raepaul
71
the fuses are all fine mate. could it be an earth problem? i just dont want to dig into all the wires if i end up looking in the completely wrong place
Feb 25, 2007
1,068
cheshire
clean all the bulb holder up make sure there is no rust or anything, check your wires for breaks its posible one is split and shorting outr on the body
lemonslap
In The Know
Mar 14, 2009
320
Kent
car is a mk3 tdi 90
Also check the output from the voltage regulator this can cause these sort of problems (should be about 14.4v with the engine running)
raepaul
71
all the connectors have been cleaned up, they were all free of rust and corrosion anyway but thought id clean them anyway.
ok cheers, i will try that and let you know if i get it sorted or not.
