Hello all, so I had a good look around before posting this and mainly the Turbo versions are discussed and not mine . I have the Seat Leon FR FSi 2.0 NON Turbo. The high pressure fuel pump is under the head rather than on top as the Trubo versions have. To get to it the entire air intake and intake manifold need to be removed plus the coolant hoses on the right hand side of engine. So , it's a lot of work to remove as i will need to find the part number for it as the pump differs from the turbo version i believe. My pump uses the Banjo bolts as found on 2005/2006 models.
Here are the VCDS codes from my scan
Engine
004195 - Fuel Pressure regulation
p1063 002 control range not reached - intermittent mil on
008854 - Fuel pressure Regulation Valve N276
p2296 - 001 - Short to plus - intermittent
008592 - Bank 2 System too rich at idle
p2190 - 002
Central Conv
01135 - Interior monitoring sensors
004 - No signal/communication - Intermittent
01134 Alarm Horn (H12)
00849 - s - contact at ignition/starter switch (d)
008 Implausible signal
Steering WHeel
00883 - Ignition Switch (D) Terminal S
012 - Electric Fault In Circuit - Intermittent
Hopefully before i take everything apart someone on this forum has had similar issues and can advise what I could or should check before dismantling.
The cars sypmtoms are revs staying low, very slow acceleration, and takes an age to reach 40-50mph.
Also any help on what the correct part for the HPFP is would be helpful as I have seen so many variations online.
Massive thanks in advance.
Engine
p2190 - 002
Central Conv
Steering WHeel
