HID Bulbs
cupralooks
More Power Needed
Jul 3, 2006
579
Hi All I have seen loads of threads for HID conversion kits, but I am not sure on 2 thinks:
1. What bulbs do I need so that they will fit my car?? H7???
What are these 6000k, 9000k???
What has everyone got??
Alex
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
There pretty blue from what ive seen mate. The 8000k are more towards purple than blue.
And side lights they've been using leds but would have to be white ones as blue isnt legal of course
cupralooks
More Power Needed
Jul 3, 2006
579
What are the ones that are really white like on the mercs??, that you can see on the motorway from miles away??
cupralooks
More Power Needed
Jul 3, 2006
579
So are they all the same brightness or the whiter you go the brighter they are??
Are you able to get high and low beam for our cars??
Alex
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the whiter or 'lower' the number the better in principle as it is allowing a fuller of spectrum of colour and hence full brightness
the higher numbers lose the white hence being more blue /purple etc but are in fact dimmer to a degree
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
sounds like you need a H4 kit - ibiza 1.4 ye ?
theres 2 kits usually too choose from
bi-xenon which is HID for both low and high beam filaments and is usually more expensive as its effectively 2 kits
low hid/halogen high which is a dual filament but only the low beam is hid cheaper too
depends how often you really use high beam in all honestly
cupralooks
More Power Needed
Jul 3, 2006
579
Yes its a 1.4 so I need H4.
I live in the country so use high beem all the time at night.
So do I need 'bi-xenon' then if I want both high beam and low beam??
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ye if you want the top dog then both elements HID or bi-xenon as sometimes described just double check the small print to make sure before you buy as they can be dearer the double ones
you'll see descriptions like this to avoid :
H4 HID Conversion Kit
Single low beam kit. This Kit comes with 2 ballasts, 2 HID light bulbs, wiring harness, screws, and other necessary hardware needed for installation. Easy installation with instruction manual
heres a pic with the different types so very simialr to look at
this is the sort of thing your after - looking about they have dropped price too so are not that much more anyway
H4 (H/L) HID KIT (6000K)
Package Contents:
• 2 bulbs (H4 High / Low - Bi-Xenon
cupralooks
More Power Needed
Jul 3, 2006
579
Package Contents:
Is this what I want???
http://cgi.ebay.co.uk/ws/eBayISAPI....m=350022115234&ssPageName=STRK:MEWA:IT&ih=022
Alex
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
*With BIXENON Kits, the bulb Extends & Retracts to switch between HI and LO Beams.
spot on from whats written there ye and a bargain too - might order some and box em up for the one dark day the Hotrod appears on a road - :p
*edit* only 1 kit - so ill leave em to you as ill be retired by the time i need some
cupralooks
More Power Needed
Jul 3, 2006
579
Well you might as well, they are bi-xenon for £50.
Cant really complain about that
What hotrod are you building??
What lump are you putting in it??
Chevy V8 would be wicked with a supercharger
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Ch*vy V8 would be wicked with a supercharger
1 - 1927 ford model t roadster
2 - Rover v8 to start off but building a 4.0 tvr block up at moment TSC
3 - should be a swear filter added for that word ;)
a TVR 4.0 with 2 of em should be fun too ;)
been offered a 540 ali big block ford complete but i think nearly 20k is a bit steep for one of my scrap rods
