Help with Guided Fault Finding Fault Memory Contents pls
neeraak
Hi All,
I'm new on here. Would really like some advice. My Ibiza Cupra 2005 has had a problem but I need someone to intepret what I have been given as a readout.
This problem came totally out of the blue just driving down the road and I would like someone to tell me what THEY think happened before I reveal what actually happened. That way I get an honest opinion of the Guided Fault Finding's Fault Memory Contents.
All help you can provide would be greatly appreciated as I think someone is trying to pull the wool over my eyes.
Here's the data (exactly as my printout shows to the letter):
01 - Engine electronics
2 Fault / notes detected
17841 P1433 035
Secondary air pump relay-J299
Open circuit
No image in the Display
Sporadic fault
18017 P1609 035
Crash shut-off was triggered
09 - Electronic central electrics
1 Fault / notes detected
01598 007
Service battery voltage
Insufficient signal
sporadic
15 - Airbag
8 Fault / notes detected
00654 032
Driver belt tensioner igniter -N153
Resistance too high
00655 032
Front passenger belt tensioner igniter -N154
Resistance too high
01214 035
Belt tensioner crash data stored
01217 032
Side airbag igniter - driver side-N199
Resistance too high
01218 032
Side airbag igniter - front passenger side-N200
Resistance too high
01218 032
Short to earth
01226 035
Crash data for side airbag stored, Drivers side
01227 035
Crash data for side airbag stored, passenger side
44 - Steering assistance
01656 035
Crash signal
No indication in display
Thanks again.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
sounds like someone has hit a kerb hard (assuming you havent noticed any panels damaged/misaligned which would suggest a bigger impact)
low battery charge would give a few errors but not these ones.
